MFD8-12 with TZT2
MFD8-12 with TZT2
Postby buckshot » Sun Jan 14, 2018 5:38 am
Will the older MFD8 or 12 work with the newer TZT2 ? I have run across a few second hand units and I wonder about using one up in the tower.
buckshot
Re: MFD8-12 with TZT2
Postby Marlin My Darlin » Mon Jan 15, 2018 9:37 am
Buckshot,
Thank you for your Question.
In order to share info to a unit in the tower you would need another TZT2 unit or a TZT. The TZT9 may be a good option for the tower. What kind of boat do you have an what other equipment is installed?
Below is a link to the TZT9 referenced above.
https://www.furunousa.com/en/products/tzt9
Marlin My Darlin
Moderator
Moderator
Postby Johnny Electron » Mon Jan 15, 2018 9:59 am
As he said, you would need to look at the TZT9 because only the TZT one system is compatible with the NN3D. You can NOT use any TZT2 unit with the NN3D.
User avatar
Moderator
Moderator
Postby buckshot » Thu Jan 18, 2018 4:55 am
Ok , Thanks
I have 2 TZT2 units at the lower helm and I have not installed anything yet in the tuna tower.
buckshot
Return to NavNet TZtouch2
Who is online
