help with older transducer
buckshot
I am looking at installing a TZTouch2 12 in my 40 Luhrs, the boat already has an Airmar B45 transducer that is plugged into a Raymarine DSM300. Can I use the transducer with my new Furuno units? Will I need any special cords/adapters? I will upgrade transducers sometime later when I bottom paint.
buckshot,
Please note that AIRMAR does make an Furuno 10-Pin Adapter Cable for the B45 Transducer, It's AIRMAR Part Number# MM-10FUR.
This adapter cable will enable you to use the B45 Transducer with the TZTouch12's internal sounder.
Hope this information helps..?
Deep Blue - :)
The transducer has been working great showing me bottom on the TZT2 but I can't get the temperature to work what would be the correct setting for the b45 transducer on this unit
