Hi there, I have a tztouch2 and have been given cmap 4d charts, this set includes 3x micro sd cards do I need to use the sdu-001 (USB adapter) to utilise these charts? Thanks
Dumptruck24,
Thank you for your inquiry. The Furuno TZTouch2 does not utilize the C-Map 4D format. The unit reads the Mapmedia MM3- format, that being said many of the most popular C-Map charts have been reformatted into the MM3 format and are pre-loaded in the TZT2 units here in the USA. A listing of the pre-loaded can be found using this link https://furunousa.com/-/media/sites/fur ... charts.pdf. Charts can be unlocked on the TZT2 by purchasing an unlock code from any authorized dealer.
