NMPG
C
Catmando
I have my TZT2 units interfaced into engines and tanks with units configuration set to statute miles. Everything shows up as expected with the exception of fuel economy. For a while economy was showing SM per gallon but now reads NM per gallon. Tried everything including resetting the system with no luck. Anyone run across this or is there possibly a setting I am missing?
JC
I would backup the settings and point and try a factory reset and then restore setting. It only takes a couple of minutes. If you still have problems with it changing, lets us know.
Give the service manager a call at our HQ. I am sure they will want to look to see if this is a software bug that hasn't been reported. (360-834-9300)
There may be a bug somewhere but I figured a way around it. By going into "units", setting the distance to Nautical Mile and then back to statute mile it seems to have triggered something and now all reads as should.
Thanks for the support.
