Synchro in progress?
Hopefully you can help me, I've just installed a 12,and a 15 TF touch 2 and i am getting "synchro in progress" when I turn on the 12 when the 15 is already on?
Also, I've been getting "communication error" as well
Any help would be massively appreciated as i am really struggling here.
The network is running through a hub 101
I have multi displays all working on the 2000 network perfectly
flusted,
It sounds like there might be a host of problems that you can troubleshoot:
Are both TZTouch2 MFDs running the same version of software..? It not, this can cause some Synchro and Communication Error Issues.
There could be an issue with the Network, and maybe possible problems with the Network Hub, or with the Network Cables. All Network Cables need to be CAT5e or better. As all Network Cables must be shielded with metal connectors, so the shield connection is passed and the data lines are protected.
There could be a noise on the NMEA2000 Backbone. I would disconnect the MFDs and see if you still get any of the Synchro and Communication Error warnings.
Just a few things to look for...
Deep Blue - ;)
