G
Gyda
I´m confused regarding installing charts on my new TZT14.
I´ve downloaded charts for my local region (SDVJENM300NMAP13.dbv), and saved them on a 32GB SD card. Putting the card in the right SD card slot on the TZT14 and violà, the chart instantly showed on the plotter ☺
On a youtube video made by Furuno Video they say that the card in the right side may contend charts, sat photos and so on, so I thought I let the card with the charts be left in the card slot. Big Mistake…
The next time I started the PZT14 it went straight to a bios window : “An operating system wasn`t found. Try disconnect any drives that don`t contain an operating system. Press Ctrl+Alt+Del to restart”
Since I didn´t have any keys to press, I had to hold down the ON/ OFF switch for 10 sec. to have the plotter turned off. Removing the SD card from the right slot, the TZT14 started as normal, but with no charts available, until I´d put the SD card in the right slot again. I´m quite sure it cant be that I have to remove the card every time I´m turning on the plotter. The problem here is that I´ve been searching the TZT14 user manual without finding any description or procedure of how to install new charts on the plotter?
Can you please advice me how to?
