Odometer questions
Gyrfalcon
We have a txt touch updated with latest software Feb 1, 2016. I know the odo reading before the update. During our first trip after the update, the odo reading and trip reading started at 0, but incremented appropriately during the trip, as far as I can recall. When we restarted the system the next day, the trip and total odo reading was 0. Page 11 of one of the software updates said you can reset odo by service menu bkclear odo&running time. How do you get to this menu? Is there some setting that automatically resets both odo measurements to zero?
Service man is under MENU - INSTALL SETUP - SERVICE MAN
password is FURUNO SERVICE.
I recommend you be careful and only reset the OD that you are seeking.
Thanks for this information. We'll go into that menu next time we're on the boat.
Is there also a setting in that menu so that our total ODO is maintained (rather than resetting to 0 when we turn off the unit)? I have double checked and the total ODO reset to 0 when we turned off our unit.
If you don't clear the OD it should continue counting but there is no re-entry option after resetting or clearing the OD.
