My TZT 12L is quite slow to respond to command inputs (to the point of being pretty annoying) compared to many other systems I have used including other Furuno MFDs. For example, after tapping the home button or swiping to get access to the menus on the top and bottom or the data boxes, it will take a few seconds to actually show the menu. Then when a further command is input such as selecting a display from the Home screen, it takes several seconds to respond. The pan and zoom functions on the plotter respond quickly but any menu-related function is slow.
The installation is on a small center console. It is extremely simple with just a single standalone unit that has no network connections of any kind or external devices other than a sonar transducer.
I have tried all kinds of things such as completely clearing the unit through a "hard" factory reset (not a "wipe") and reinstalling the unit software. I am running the most recent version (3.01).
Is there anything I can do in the settings that might reduce the processing load and speed up its response? Does it help to delete unused chart files and free up memory? It is a nice unit with an excellent screen and works fine as long as you don't mind waiting.
