DST-800PSF Smart Sensor Temp Anomaly
Postby Yeti » Sun Jul 17, 2016 9:37 am
Data is reading ~120 F.
Given our temperature in Puget Sound averages around 55 F., I know this can't be correct. I've searched the menu for a calibration function but without out any luck. Am I missing something here, or is the sensor on the fritz?
Yeti
Re: DST-800PSF Smart Sensor Temp Anomaly
Postby Johnny Electron » Mon Jul 18, 2016 4:15 am
If the smart sensor is putting out incorrect data, you should see if you can correct it in the display unit by applying an offset. It also could be the device you are using has an incorrectly applied offset. If you find you can't correct it, then the DST-800PSF would have to be replaced.
Johnny Electron
User avatar
Johnny Electron
Postby Yeti » Mon Jul 18, 2016 5:23 am
Thanks, Johnny.
I guess I should have mentioned that my data display instrument is a FI-503. In looking on the web, it appears there is an "offset" adjustment in the menu (which I never could find). I'll give it another wack.
Yeti
Postby Acer » Fri Aug 26, 2016 4:42 am
My first smart sensor showed "crazy" temperatures after 2 years, temps were inrcreaisng til value wsa out of range.....repaced the sensor, same defect after another two years.....
Acer
Postby twistedtree » Sat Sep 10, 2016 5:31 pm
I've got a DT-200 (Same thing but without speed) and the temp has gone nuts on it too. Searching around, it seems to be a very common problem.
twistedtree
Postby Acer » Sun Sep 11, 2016 11:41 pm
Good to know. If its a common Problem I will contact Airsense what they offer in return for that repeating failures
Acer
Return to Instruments
