T2000
Good morning,
We have a T2000 temperature indicator that scrolls through a self check when powered on then indicates "Lo". There is no sign of a transducer ever being connected to it. It seems someone started an installation but never completed it. Also the flush mount bracket was never installed. Is the two piece mounting bracket still available? Can this unit be returned for testing/ repair and calibration before we buy a transducer? Is there a replacement that fits the hole as it is flush mounted? Thank you and have a good day.
Rich
You can send the unit in for testing to see what the service center finds about it condition. The bracket for this old unit is not available but the temp transducers are.
Hi, I need to know what is the part number to buy a T-03 replacement sensor, we need only the sensor with cable, no the others parts.
Thanks,
Roberto
Hello Roberto -
The part number for the sensor is CAT2000/RTH.
