Furuno Autopilot with Verado o/board
Hi Guys,
I'm looking to install a Furuno AP but getting conflicting info about the Mercury Verdao install. I understand that the Verado has its own power steering pump and would like to find out how the AP pump is connected into the system.
Also keen to fit a linear rudder feedback unit but having trouble finding info on the bracket mount for the feedback when fitting to Verado.
Info and advice greatly appreciated.
thanks
Our newer pilots use virtual feedback and work well with the Verado. The only reason for an RRU would be if you are running an older Furuno pilot or need the extra fishing patterns. Fitting an RRU is very hard with the verado because it is very tight near the engines. Furuno used to offer verado kits for the rru but no longer available.
