flowmotion
I will be using a TZtouch2 and would like to interface to the Yamaha Helm Master system to view engine data. From what I have read it typically takes a Yamaha interface consisting of: Interface unit 6YG-8A2D0-00 and wire lead 6YG-82521-00.
Are those interface devices also required for the Helm Master system or does Helm Master output the necessary information directly to the NEMA 2000 bus?
Same question re the Yamaha engine hub. Is that required or supplied with the Helm Master?
I am also confused about Fish Hunter mode for the 711C/OB autopilot. From what I am reading it is limited or not available due to the use of Fantum Feedback. Does this still apply to the Helm Master?
Thank you
Thank you
