711C Alarm Message
I'm getting a "Position source has changed" alarm regularly, particularly when going slow speeds near shore or marina. Can't find that message in the manual.
If your plotter isn't losing positon but the pilot is, it sounds like a NMEA 2000 bus problem or a short loss of position that is too short for the plotter to switch but the autopilot is. I would recommend contacting your dealer or at least discussing the case with Furuno support while you are at the boat.
