seaveepete
I've spent the last two weekends installing a new 711C AP system on my boat. Took longer than expected because I had challenges with locating the PG700 and also decided to replace ALL hydraulic steering hoses.
I've got everything plumbed back up and need to purge the system now. I'm looking for advice on how to purge the Seastar steering system (helm plus HC5345 ram) properly. By that I mean, how to manually run the AP pump in a controlled manner to purge air from the lines. I know how to fill/purge a normal system without the AP pump. Looking for some advice specific to systems with the pump. The AccuSteer manual with the pump was useless.
Thanks,
Pete
BTW - This 711C install is a pain. Had I known that the 711C AP setup was not "plug-and-play" and would require stripping all those 20 gauge wires from the heading sensor and control unit and trying to insert them into those tiny connector blocks I would have gone with the Garmin. Come on Furuno!!!
Thanks,
Pete
