Missing Radar Overlay
Status
Not open for further replies.
Acer
Using actual Maxsea V2.04 with tztouch and Radar. No Problems in the past, I was able to Switch Radar on/off and Change the range etc etc etc.
Tested it again after Updating to the 3.12 Firmware of the tztouch. I dont know if it is coinsidence but I lost Radar overlay in Maxsea. I can still controll the Radar via the Software (on/off) but now overlay anymore.
Any hint is wlcome
Oliver
I will check that next time on the boat. But I have had always Hdg and the Installation wasnt modified. But thanks for the hint.......
Well, in the past I could Switch on/off whenever I wanted. tried xou advice but no Change, I can Switch the Radar on/off and do everything like in the past, only Thing is missing is the Radar Display
Another hint?
Well, at least I found a Workaround.
My Nav-PC is connected to the Navnet via Ethernet and to my Router for Internet Access via wifi. If I disable the wifi-connection I get Radar overlay back.
The "funny" Thing is that I didnt Change anything but updating the Firmware of the TZT.
Perhaps the Software development guys made some changes regarding the handling of the Radar data??
It think it has more to do with the shared resources that many PCs use for Ethernet and Wi-Fi adaptors. I am glad you found the cause.
Status
