Have a 12" TZT2 with DFF3D which I am about to start using.
I have figured out that I cannot display chart and multibeam at the same time.
Is there a way to add another monitor and extend the display so that both can be viewed at same time ?
Noted that I can view chart and sounder in a split screen however I do not have a sounder connected, can you confirm that the depth displayed on the pop out box at the bottom of the chart display is coming from the DFF3D.
Also have a DFF3 from another project which I am considering adding to the network so that I can view beyond the DFF3D range, guessing that it would be connected to TZT2 via an ethernet hub/switcher and could then be selected as the sounder on TZT2 menu.
DFF3D is using a flush mounted B54 transducer, do not yet have a transducer for the DFF3.
Is there a risk of interference or transducer cross talk if the DFF3 and DFF3D were used at the same time ?
