I am having a problem with my RD30 using depth and temperature with an Airmar transducer.
Furuno 235DHT-LSME Airmar 44-082-1-01. My original transducer would function properly
for an hour our so then indicate bars across the screen. I found on this forum that if the sentence was highlighted on the Aux Port display the transducer was sending info, the original transducer was not highlighted during a failure so I assumed the transducer was bad.
I ordered a new transducer,which has to be purchased as a thru hull assembly for $600. I lowered it into the water over the side of the boat to make sure it was working before running 25 ft of cable. It worked fine for the 10 minutes I tested it. After the installation, the first day out, the display intermittently will show around 325 ft or 1.8 ft then back to the correct depth. The failure only last a second or two then displays the correct depth. I cruised about 5 hours today and witnessed an intermittent display a half dozen times. When there is a failure it is always around 325 ft or 1.8 ft, never in the mid range.
I am assuming the new transducer has a problem but wanted to reach out for other ideas before sending to the Furuno for testing.
