I have a couple questions about the pre loaded charts. I currently have C map charts MM3-VNA-022 Vector and MM3-FNA-022 fishing unlocked and I want to add MM3-V90-6PO Vector Navionics to it. Can this be done? I don’t see it on the list in my catalog so I guess I would need to load it on the card that is in the unit correct. If this can be done will this chart be listed on the same menu I use now when I swipe up from the bottom of my screen? Will I be able to switch from c map to Navionics from this screen? Another question is how do you know if the two c map charts listed above are current or can be updated? Is there some source you could recommend to go to to better explain the use of the pre loaded charts as i don’t get much from the manual.
Thank you!
Thank you!
