G
glsawyer
I just picked up a vx2 c-map unit. rdp-149. got it and its cables for $120 shipped from Florida to Alaska. guy said it would shut off after a few minutes. got it today. took it apart. cleaned the corrosion and everything with alcohol. including the stuck trackball. been running over an hour now and works great so far! ill be getting a new c-map card for it. sadly they are almost $400! that said is there a cheaper gps antenna then the Furuno one that will work? also what domes and open arrays will work? between 4-8kw.
I also was told I need the black box in order to use my transducer? it did come with the etr-6/10n
