Hammerhands
I'm Brandy new to this forum and grateful it's here. I am in the process of up fitting on a 1985 26' Blackman Fishmachine to all Furuno. I will be installing a new Hydraulic Steering system from Uflex, basically Helm# UP33fm @ 2 cubic inches, UC133IOB Cylinder @ 10 cubic inches it will be going thru the stock power steering Volvo system. This combination should give me a clean 4 turns knock to knock. I'd like to understand what would be the best match up of a Furuno full kit A.P.system and if in the kit, the necessary (tie in) T's or adaptive fittings, are included. This is a older but very sanitary 6 cyl Diesel AQAD40B / 290 Duo prop propulsion combination. Thank you in advance to all you Guru's that respond, I will also be picking brains in the Electronics Forum for tips on making the TZT312" the best it can be!
