I have just bought a sail boat. the prior owner told me the radar works, however unit has the error message "no bearing pulse". I have tried the diagnostics and set up and received an NG.
the unit is attached to Furuno GPS and works as a repeater in this capacity.
I believe the rotor is turning. The cable was split and has a coupling bar, which is mounted inside a metal box. It appears that the unit was professionally installed at the time of original installation. I tried cutting back the coaxial cable inside the bundle and worked on this connection. I also cleaned the outer shield cable. the larger colored wires do not have any obvious corrosion.
the display appears to show a sweep but the return on the display only shows a tight cluster of Noise.
I wonder if there is anything further I should do before I either hire a professional, or reutrn the unit for service. I have a delivery run up the coast of southern New England USA in two weeks, Radar woudl be helpful
thanks
thanks
